Beantowm111
Mar 05, 2023Apprentice
RBS850 which port Connect Ethernet?
Hi - when hard wiring an Orbi rbs850 satellite to the router does it matter which of the four Ethernet ports on satellite you use? None seem marked with an inbound feed indication like with router?
- Mar 06, 2023
Glad you got it figured out. Might mark it solved so others aren't still trying to fix it
