Nes2
Apr 04, 2024Aspirant
RBS850 Wi-Fi disabling
I need to use an RBS850 for an Ethernet connection only. However, other Wi-Fi devices connect to it. How can I prevent Wi-Fi connections to this satellite??
- Apr 05, 2024
For any gaming for simulator applications, ethernet connection from the game console or PC would be recommended to ethernet connect to the RBR for best and optimal performances. They make varied lengths of LAN cabling to support distances needed. CAT6 UTP is recommended.
As mentioned, Wi-Fi on any Orbi system can not be disabled. Would negate the intended design and use of a MESH system as it's supposed to be online and running all the time.
