lw187
Sep 29, 2020Guide
RBS850 Wired Backhaul - Out of Sync Satellite / Chromebook Connection Issues
RBR850 connected to 4 wired RBS850 satellites. One satellite continues showing up as "out of sync" - no devices are able to connect to its wifi, either. Further, two chromebooks that get heavy u...
Sep 29, 2020Guru - Experienced User
Are all RBS wired directly to the RBR or is there a LAN switch in between the RBR and RBS? I there is a switch,
What is the Mfr and model# of the ethernet switch in the configuration?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://https://https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Power OFF ALL RBS. Power ON the one problem RBS to see if it correctly syncs.
Try swapping this one RBS with a known working RBS to see if the problem follows.
- lw187Sep 29, 2020GuideThank you so much for the reply. Verizon G1100 Quantum Gateway set to bridge mode. That goes to the RBR850 (router mode), and the RBS850s are wired directly to the RBR.
Nothing new but noticed some real crappy connectivity with the newer Chromebooks (Galaxy 2020) and Acer 713.
3.2.16.6.1.4.4 around the horn for FW.
