lw187
Sep 29, 2020Guide
RBS850 Wired Backhaul - Out of Sync Satellite / Chromebook Connection Issues
RBR850 connected to 4 wired RBS850 satellites. One satellite continues showing up as "out of sync" - no devices are able to connect to its wifi, either. Further, two chromebooks that get heavy u...
Sep 29, 2020Guru - Experienced User
Try changing the CTS value to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
If not, try disabling AX mode. Seen some posts that chromebooks don't like the AX mode.
lw187
Sep 29, 2020Guide
Thank you will do and report back
- lw187Sep 29, 2020Guide
Was already on 2347.
I'll try rebooting Verizon router, and in turn the Orbis, see if all satellites can stay in sync and go from there i guess. Would rather not disable ax, but i guess when it comes down to it the only wifi-6 devices i have are the chromebooks so if i disable ax everything else will be unaffected right?
