donawalt's avatar
donawalt
Hero - Experienced User
Mar 19, 2021
RBS850 wired backhaul questions
OK, I found I have a gigabit connection into an room where I have a satellite RBS850. So I have a few questions before moving it from wireless to wired backhaul, that I couldn't find in any of the in...
  • FURRYe38's avatar
    You got it.
    Check the RBRs web page. The status for the one RBS should be wired after that.
