TobiasNo
Oct 19, 2024Aspirant
RBS850
Hi, Just bought a new sattelite to add to my network, it just not want to connect to the system. I have tried to update my router, unplugged the system and even put it the whole network back to f...
TobiasNo
Oct 21, 2024Aspirant
Hi,
Bought it from a retailer, not sure Netgear has customer service in Norway.
CrimpOn
Oct 21, 2024Guru - Experienced User
- CrimpOnOct 21, 2024Guru - Experienced User
Something to try...
Manually install Firmware on Orbi Satellite
On most of the Orbi satellites, when the satellite is Factory Reset it will respond to a web connection on one of the LAN ports at IP address 192.168.1.250.
This creates an opportunity to manually load any version of firmware on the satellite (but it is not a trivial process!)
- Find the desired firmware on the Netgear support site.
- Download to a computer and unpack the zip file to extract the firmware image.
- Disconnect the computer and the satellite from everything else and connect them with an Ethernet cable.
- Set the computer to a Static IP address in the 192.168.1.1 LAN (anything besides 250 and 255. I chose 191.168.1.1, subnet mask 255.255.255.0.
- Power up the satellite, hold the Reset Button (inside that tiny hole) until the Power LED begins to flash amber, and wait a couple of minutes for it to activate. (I recommend wine.)
- On the computer, open a web browser to the IP address 192.168.1.250 (This may take several seconds to load)
- Log into the satellite home page (The credentials will be “admin” and “password”)
- Select the bottom menu item, Firmware Update.
- Navigate to the location where the firmware file is saved on the computer and select it.
- After the firmware loads, the computer will no longer be connected to the satellite.
- Restore the default situation: Remove the Ethernet cable. Change the computer back to the normal IP setting (DHCP) and connect it to the Orbi system.
- Connect a web browser to the Orbi web admin.
- Select the bottom menu item, Add Orbi Satellite.
- Go through the process using the Sync buttons, and “Voila”, the satellite should appear in the Attached Devices display.
