Chuck_M
Jan 31, 2021Mentor
RBS850s Show Different Statuses But Are Identical: Bug?
My RBR850 is running firmware version V3.2.17.12_1.4.14 and has never performed better. Speeds are high and connectivity is rock solid. I have three RBS850s also connected -- two via hard wire a...
- Jan 31, 2021So after a simple reboot of the satellites, all looks good. The sattelites are now reporting the proper encryption.
Thanks much.
Jan 31, 2021Guru - Experienced User
I ran into a odd issue this past week with 1 of my RBS, wired. Was showing "out of sync" on the RBRs status page. Other RBS was fine. RBS web page showed it was working fine and had connected clients connected. No front LED was on or blinked. Just the status on the RBRs web page was not Good. I had to power OFF the RBS, reset, wireless re-sync the RBS to the RBR after it finally synced, wire connected it again and it's been online and showing GOOD as the status since then. No idea why the status changed or what happened. I gathered logs and sent off to NG for review. No responce.
I would reset and resync your RBS.
When RBS are wire connected, the wifi icon for 2.4 and 5Ghz will be grayed out. This is normal.
- Chuck_MJan 31, 2021Mentor
Thanks FURRYe38 , I will power cycle them later today and check status. If it is still odd, I will reset the satellites as recommended and check. Either way I will report back what I find.
Funny thing is that the network is running better than ever; I should have never looked at the satellite pages! LOL
- FURRYe38Jan 31, 2021Guru - Experienced User
Ya things are working well here too. Was an odd thing I found with mine. The other day, I had my 2nd gen NEST disconnect and would not reconnect at all which was a odd thing, never had seen that before since I had the Orbi AX installed. That took just a reboot of the RBS. All been ok since that night. Makes me wonder if NG does soemthing from behind the scenes remotely.
- Chuck_MJan 31, 2021MentorSo after a simple reboot of the satellites, all looks good. The sattelites are now reporting the proper encryption.
Thanks much.
