Chuck_M
Jan 31, 2021Mentor
RBS850s Show Different Statuses But Are Identical: Bug?
My RBR850 is running firmware version V3.2.17.12_1.4.14 and has never performed better. Speeds are high and connectivity is rock solid. I have three RBS850s also connected -- two via hard wire a...
- Jan 31, 2021So after a simple reboot of the satellites, all looks good. The sattelites are now reporting the proper encryption.
Thanks much.
Chuck_M
Jan 31, 2021Mentor
Thanks FURRYe38 , I will power cycle them later today and check status. If it is still odd, I will reset the satellites as recommended and check. Either way I will report back what I find.
Funny thing is that the network is running better than ever; I should have never looked at the satellite pages! LOL
Jan 31, 2021Guru - Experienced User
Ya things are working well here too. Was an odd thing I found with mine. The other day, I had my 2nd gen NEST disconnect and would not reconnect at all which was a odd thing, never had seen that before since I had the Orbi AX installed. That took just a reboot of the RBS. All been ok since that night. Makes me wonder if NG does soemthing from behind the scenes remotely.
- Chuck_MJan 31, 2021MentorSo after a simple reboot of the satellites, all looks good. The sattelites are now reporting the proper encryption.
Thanks much.
