4vrnvr
Apr 09, 2023Apprentice
RBS860 Disconnected
Hi All, I have an RBR860 and an RBS860 that had been working fine. Router was using firmware 7.2.3.12 and just did an update to 7.2.4.5. After the update the Satellite went to disconnected. Tried...
- Apr 09, 2023
So I reset the router, but upon booting up it automatically checked for an update and updated. I downloaded the old version and did a manual update so I was back on 7.2.3.12 then quickly disabled the auto update. I then did the sync with the satellite and it sync'ed up without any problems. I then checked the firmware on the satellite and it was already at the newer 7.2.4.5. I am too chicken to try updating the router to 7.2.4.5 since the satellite is currently syncing up.
Two things I have noticed. My device list in the Orbi App doesn't load, keeps saying try later.
Another strange thing is that my TV that is in the room with the satellite wouldn't accept the wifi password, so as a last result I tried using the password on the label on the bottom of the satellite and it logged right in to the network. Never had this happen before, but it's my only device currently connected to the satellite. Any ideas on this?
Thanks!
Apr 09, 2023Guru - Experienced User
Please update the RBS first to newer versions of FW, then follow up with the RBR update lastly.
- 4vrnvrApr 09, 2023Apprentice
Thanks Furry, but how would I actually do that? I did download the updated satellite firmware zip file, but since it's disconnected I can't manually update. Any help would be greatly appreciated.
- FURRYe38Apr 09, 2023Guru - Experienced User
Will the RBS sync up any if ethernet connected to the back of the RBR? If it can you could use it's IP address it gets here from the RBR to log into the RBS web page and sent the FW file directly to the RBS.
IF not, you'll need to down grade the RBR to what you had loaded to get the RBS to sync up, then quickly update the RBS to most current version, then update the RBR lastly.
I tried plugging the satellite into the router via ethernet connection and the satellite went to magenta, although I didn't try to actually hit the resync buttons. Should I replug it in and hit the sync buttons?
Sure seems this is more difficult than it should be.
Thanks again...
