4vrnvr's avatar
4vrnvr
Apprentice
Apr 09, 2023
RBS860 Disconnected
Hi All,   I have an RBR860 and an RBS860 that had been working fine. Router was using firmware 7.2.3.12 and just did an update to 7.2.4.5. After the update the Satellite went to disconnected. Tried...
  • 4vrnvr's avatar
    4vrnvr
    Apr 09, 2023
    So I reset the router, but upon booting up it automatically checked for an update and updated. I downloaded the old version and did a manual update so I was back on 7.2.3.12 then quickly disabled the auto update. I then did the sync with the satellite and it sync'ed up without any problems. I then checked the firmware on the satellite and it was already at the newer 7.2.4.5. I am too chicken to try updating the router to 7.2.4.5 since the satellite is currently syncing up.
    Two things I have noticed. My device list in the Orbi App doesn't load, keeps saying try later.
    Another strange thing is that my TV that is in the room with the satellite wouldn't accept the wifi password, so as a last result I tried using the password on the label on the bottom of the satellite and it logged right in to the network.  Never had this happen before, but it's my only device currently connected to the satellite. Any ideas on this?
    Thanks!
