viatorcaeli's avatar
viatorcaeli
RBS860 does not react
Dear Community,
after I added another RBS860 to my RBR860 (router + 2 satellites) - which was itself quite a challenge as I had to reset all of the devices.
Now the additional satellite doesn't react anymore. The power LED is continously orange. The RBS860 doesn't react to:
  1. remove power cable - reconnect power
  2. press reset button for 10 sec
  3. use 30/30/30 method
Still no reaction...just a lonely constant orange light.
Are the any other possibilities to reset the RBS? What else shall I do to get the RBS back into my network?
Thanks a lot!
  • FURRYe38's avatar
    If you updated the new RBS to same version of FW as on existing system, and did all the troubleshooting, then the RBS maybe faulty and would need to be replaced.
  • Yes, the RBS has had (until it "went of grid") the same FW version as the other satellites in my network. Doesn't sound that good - to replace a satellite half a year after the warranty has ended. Especially considering the price of such a device. :-/
    Thanks!
