Ericasjourney
Oct 03, 2023Aspirant
RBS860 Satellite Won't stay connected to RBR860 Router
I have my primary router which has always been rock solid. I also have a satellite located ~50' away in an accessory building where my home office is located. It's generally worked great with no issu...
Oct 03, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Might update RBS first then RBR lastly.
Ericasjourney
Forgot to answer your others, apologies:
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update? Yes did all that earlier in the day when the issue wouldn't go away. I always unplug all the network devices for 5 min, plug in ISP modem, wait 5 minutes, plug in main orbi router, wait 5 min, then plug in the satellite. I've also done a hard reset 3x on the satellite and attempted to reconnect. Always get the blue light but never appears in the list on both app and browser.
