donawalt
Jun 01, 2024Hero - Experienced User
RBS960 satellite memory creep again
Just started - noticed it early this morning. As it shows, it's been up for over 3 weeks. It will be interesting to see if it stops or if it ends up restarting or losing its connection via backhaul. ...
donawalt
Does the RBS exhibit the same thing or different. This is the RBS. The other RBS is fine.
Keep monitoring and see if this one RBS fails. - News flash! It went all day to 6:41 PM, now up to 476MB. I had to try something lol - I unplugged the Eth cable and after 2 minutes (LED was magenta - too far aw3ay for WiFi Backhaul) I plugged it back in., It's only been 20 minutes, but the memory has already dropped TWICE! 473 then 472. I'll keep watching, then if that continues update my support ticket with this failure.
Wondering if you swapped RBS around if the problem would follow.
FW v.31? It may take 22 days!
donawalt
Forgot to reply to last question - yes - 7.2.6.31 FW.
