donawalt
Jun 01, 2024Mentor - Experienced User
RBS960 satellite memory creep again
Just started - noticed it early this morning. As it shows, it's been up for over 3 weeks. It will be interesting to see if it stops or if it ends up restarting or losing its connection via backhaul. ...
Jun 03, 2024Guru - Experienced User
đ
TC_in_Montana
Jun 04, 2024Virtuoso
With Don's help and several debug logs, I think I have found the runaway/looping process... I have documented my thoughts and findings and it is attached as a pdf file.
The TLDR version is: The Process d2d /tmp/dal/d2d is in a write loop or something is causing it to write thousands of lines of data to a temp area - causing memory growth.
