donawalt
Jun 01, 2024Hero - Experienced User
RBS960 satellite memory creep again
Just started - noticed it early this morning. As it shows, it's been up for over 3 weeks. It will be interesting to see if it stops or if it ends up restarting or losing its connection via backhaul. ...
Jun 05, 2024Guru - Experienced User
This 3AM restart, was that on it's own or did you intervene?
Wondering if you should open up another support ticket for this particular issue. 🤔
donawalt
Jun 05, 2024Hero - Experienced User
No, it did it on its own - likely out of memory.
I added this info to my existing support ticket, as my original problem indicated memory creep issues among other problems. I had another support ticket open with similar issues, and they closed that one - I think they wanted this all lumped into one support ticket.
- FURRYe38Jun 05, 2024Guru - Experienced User
Thank you. Ok, sounds good.
Will be checking in on this as well.
- TC_in_MontanaJun 05, 2024Virtuoso
In reviewing Don's debug files post satellite reboot....
Two of the files noted in my research show quite a large growth quickly.
firmware_log.txt had entries showing from 5:07AM - 6:46AM.
This file was 6,200 lines totaling approximately 450K in size (pre-zip - so that is the size within virtual memory).
Of those 6,200 lines, there were a group of approximately 20 lines repeated over and over.
led_event_log had entries with only a few lines with timestamps (this is normal). Total entries were 4,230 lines totally 180K in size (pre-zip). Of those 4,230 lines, approximately 4,000 were the same REPACD : GW IP[192.168.1.1] reachable via eth0 entry.
Just for informational purposes - the d2d /tmp/dal/d2d VSZ was 1548 (compared to 153m from the other satellite). We did not get a total size from the satellite that was > 700MB memory usage because we did not want to risk forcing a restart - we wanted to see when it would do it's own restart).
This shows that there are some other processes other than d2d /tmp/dal/d2d that is doing runaway writing/logging that if not causing memory usage, it is definitely using resources.
- donawaltJun 08, 2024Hero - Experienced User
Another data item in the memory creep saga - when the RBS originally restarted on its own this week because memory had climbed to 782MB, according to the logs it made 12 DHCP requests - and as reported, it came up with hop count blank. So maybe, hop count issues are related to DHCP issues:
Can't get DHCP info -> keep trying DHCP requests -> hop count stays blank until it gets its DHCP info......
Note the times of all these DHCP requests at the moment the RBS960 was restarting on its own:
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:01:32
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:01:42
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:01:52
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:03:19
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:03:29
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:03:35
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:03:47
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:05:08
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:05:56
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:06:26
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:06:41
[DHCP IP: (192.168.1.148)] to MAC address XX:XX:XX:XX:XX:XX, Wednesday, Jun 05,2024 03:06:56
