roninremy
Dec 06, 2023Guide
RBSE960 Add-on Satellite Use as main router/switch
I was thinking of picking this up (mostly because of the price) but as it is a "satellite" I was wondering if I could use this as my router/switch or if it can only be use as a satellite? I ca...
Dec 06, 2023Guru - Experienced User
The RBS are remote wireless APs that connect to a main RBR orbi router for connection.
RBS require the RBR unit to connect to operate correctly.
When setup the RBS has ethernet ports in back for ethernet connections to wired devices.
