atiq020
Nov 25, 2022Aspirant
rbse960 always show POOR BACKHUL status
my rbse960 sattelite are always show poor status but its not far from the router rbr960 ? i already upgrade the latest uptodate firmware
CrimpOn
Nov 25, 2022Guru - Experienced User
How far is "not that far"? What sort of building materials are in the path between units?
- atiq020Nov 25, 2022Aspirant
its new home mostly inside all wood small room and not far from router basically say 30 feet upstairs router and sattlite downstairs
- CrimpOnNov 25, 2022Guru - Experienced User
Thanks. 30 ft. is a "normal" distance. If the connection is reported as "Poor", there must be something blocking the WiFi signal between the two units. Could be AC ductwork. Metal appliances. a lot of wooden floor joists. Sometimes moving the router or satellite around will find a better path.
- plemansNov 26, 2022Guru - Experienced User
Try actually testing the connection. Hardwire a pc/laptop into the satellite and see what speed it gets. that way you can check if it actually does have a poor backhaul or it the GUI is wrong.
