atiq020
Nov 25, 2022Aspirant
rbse960 always show POOR BACKHUL status
my rbse960 sattelite are always show poor status but its not far from the router rbr960 ? i already upgrade the latest uptodate firmware
atiq020
its new home mostly inside all wood small room and not far from router basically say 30 feet upstairs router and sattlite downstairs
CrimpOn
Nov 25, 2022Guru - Experienced User
Thanks. 30 ft. is a "normal" distance. If the connection is reported as "Poor", there must be something blocking the WiFi signal between the two units. Could be AC ductwork. Metal appliances. a lot of wooden floor joists. Sometimes moving the router or satellite around will find a better path.
- plemansNov 26, 2022Guru - Experienced User
Try actually testing the connection. Hardwire a pc/laptop into the satellite and see what speed it gets. that way you can check if it actually does have a poor backhaul or it the GUI is wrong.
