jaberle
Jul 31, 2022Aspirant
RBSE960 does not fully come online after reboot with TP-Link Access point connected
Hi, I have an issue in my home where I have a RBR960 Router connected to two RBS960 satellites using wireless backhaul. One of the RBS960 Satellites has a wired TP-Link(AC1750) Access point connected...
- Jul 31, 2022
I would presume that the DHCP service on the TP Link was the problem since you disabled it and things are working now.
Glad you seem to figure it out. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 31, 2022Guru - Experienced User
What FW version is loaded currently?
What CAT# lan cable are you using?
What LAN port on the RBS are you using?
Does the RBS come online fully with out the TPLink device in the middle?
jaberle
Firmware: 6.0.3.85
Cat6 cable(not the issue, this has been working for years with other Routers and access points)
Yes, as stated, everything works if the RBS is brought online without the TP-Link cable plugged in. Once the RBS has established its sync with the RBR, I can plug the TP-Link cable in and everything works as expected. I suspect that there might be a setting or something on the access point TP-Link, but the odd thing, is that the RBS acts like everything is great, no LED's, but anything attached to it, does not get passed through to the router. thanks!
- jaberleJul 31, 2022Aspirant
Update: I think I may have resolved. The TP-Link although in Access Point mode, had DHCP server on Auto. I turned this to Off, since all DHCP should be coming from the Orbi. I've rebooted the RBS and it came back online completely without any removal of cables. I'm not exactly sure that was the issue, but seems to be ok now. thanks.
- FURRYe38Jul 31, 2022Guru - Experienced User
Enjoy. 📡- jaberleAug 25, 2022Aspirant
My issue has returned. In this case, and in the past, when the spectrum service is disrupted, one of my satellites (RBSE960) does not come fully online. It allows connections, but anything connected to it does not connect to the internet. In order for me to get this back, I had to power off and pull the physical cable from the RBSE960 to the TP-Link access point. Then once it is online and I confirm Internet connectivity, I can then plug back in the TP-Link and it connects just fine. Anyone have any ideas? This has happened a number of times, similar happens if the Router is restarted, I can not get this particular satellite connected without the above steps.(most of the time). Thoughts?
