PAB3
Jul 30, 2024Aspirant
RBSE960 Satellites not attached to RBRE960 Router
About a month ago my Orbi RBSE960 satellites (2) no longer show as attached to the Orbi RBRE960 router. I’ve had this system for about 2 years. The firmware on the router is up to date. The satellites...
- Aug 01, 2024Thank you FURRYe38! All firmware was the most recent. I was able to factory reset the router and both satellites. Rebooted the ISP modem and let it come back up. Connected the Orbi router to the modem. Setup a “new” Orbi system with just the router. Once the router was successfully up and running, I added each satellite back one at a time. Everything is up and the satellites are reflected as part of the network, both online and in the app. I appreciate you replying!
Aug 01, 2024Guru - Experienced User
What FW version do you have loaded on the RBR and RBS?
Was the FW on the RBS updated first, then the RBR lastly?
Are you first wirelessly syncing them to the RBR, while in same room as the RBR or near the RBR?
Are the RBS ethernet connected normally or wirelessly connected normally?
- PAB3Aug 01, 2024AspirantThank you FURRYe38! All firmware was the most recent. I was able to factory reset the router and both satellites. Rebooted the ISP modem and let it come back up. Connected the Orbi router to the modem. Setup a “new” Orbi system with just the router. Once the router was successfully up and running, I added each satellite back one at a time. Everything is up and the satellites are reflected as part of the network, both online and in the app. I appreciate you replying!
- FURRYe38Aug 01, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
