niqolas619
Sep 29, 2024Aspirant
RBSE960 satellites won't connect to router nor computer via wired
Both of my satellites just randomly stopped connecting one day about a month and a half ago - just now getting some time to look into it. Not sure if they grabbed an auto FW update or something - I h...
niqolas619
Oct 06, 2024Aspirant
I was able to talk to the problematic sattelite via the method CrimpOn suggested. I downgraded that FW to v21 and rebooted, but I'm still not able to get this satellite recognized in the Orbi app. I had high hopes for this, because prior to this the satellite just seemed dead to the world. This at least shows me that something is still operational inside it, it just isn't communicating enough to sync up.
I've since downgraded the Orbi router to v21 as well. So now I have that router and both satellites on v21, with one satellite working as expected and the other not accessible via the app sync process.
Is there a web or direct connect way to sync up satellites outside of the app?
niqolas619
I should say, too - the white LED just continues to flash white at 1Hz on the front of the satellite. Documentation seems to say that the LED should go to solid white at some point after booting, but that's not the case for me.
For the satellite that was previously not working but I was able to recover by downgrading the FW, it was showing the same behavior - only flashed white forever, never went to solid.
Not sure if any of this is meaningful. At the least it's frustrating that both working and non-working devices don't match the documented behavior.
- CrimpOnOct 06, 2024Guru - Experienced User
I have been more successful using the Orbi web interface method to sync satellites. Bottom item on the home page menu.
The process would be to Factory Reset the satellite, delete it from the configuration, and then use the Add Orbi Satellite process to sync it to the router. I always perform this task with the satellite in the same room as the router (removes need to hustle through the house, up/down stairs, etc. to press the buttons.)
After the satellite shows up on the web Attached Devices display with a status of "5G WiFi Good", then connect it to the router with a short Ethernet cable and wait about 5 minutes until it switches from WiFi connection to 'Wired'.
