rdt40ish
May 23, 2021Aspirant
RBx 850 - Android app network map
All, i just installed my new RBRx system and "think" i have my RBS setup via a backhaul using the WAN port. Is the network image on the app real or... It currently shows a dotted line from the RBR a...
May 23, 2021Guru - Experienced User
Are you ethernet connecting the RBS to the RBR? If so, it should be connected as described here:
Dotted lines between the RBR and RBS on the app means the RBS is wirelessly connected to the RBR, solid line means the RBS is ethernet wire connected to the RBR.
rdt40ish
Do if i simply change the ethernet cable from the internet port to the ethernet as the last image shows i simply cant get an internet connection. even rebooting my modem has not helped.
do i need to set this up in bridge mode?
Missing something simple i'm sure/
