satelly
Jan 26, 2022Aspirant
RBX350 Wifi Ax Connection
The connection page shows that devices are connected to either 2.4 or 5GHz. However for 5GHz connections, I cant seem to find whether it is connected to wifi-5 (ac) or wifi-6 (ax). Does the Orbi dist...
- Jan 26, 2022
Its not that simple.
Try reading through this article to learn a little more about wifi and how it works.
Jan 26, 2022Guru - Experienced User
Its not going to say whether its connected to AC or AX
- satellyJan 26, 2022AspirantThanks. Is there any way of checking either in the Orbi program/app or other apps whether the connection is ac or ax?
