MikeS2021
Mar 22, 2022Aspirant
Re: 1 -2 times per day router goes offline
HomeUserguy, We are both seeing the same issue and getting the same obscure questions (how far apart are the satellites, etc.). I find it hard to believe that there isn't any form of logging that w...
Mar 22, 2022Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Changes made: v4 FW
Turned off AX for 2.4
CTS set to 2347
Domain Name Server (DNS) Address - Use These DNS Servers
and set all devices to have Reserved IP addresses
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR750-RBS750-Firmware-Version-4-6-5-14-Released/m-p/2168160/highlight/true#M23552
Since updating mine, I have not seen these issues.
