Aggie88
Feb 11, 2025Apprentice
20/40MHz Coexistance (RBK963)
I have tried responding to the thread titled "Orbi 960 2.4GHz Bug Causes Devices to Disconnect from 5GHz and 6GHz Networks" twice now. Yesterday's response disappeared in a couple of hours and today...
Feb 12, 2025Guru - Experienced User
Basements are not recommended or good locations for the main RBR unit. All that concrete and steel will cause problems and can inhibit good signal travel. Main level or 2nd level is recommended.
What FW version is loaded on the system?
Same channels I use. I usually keep 20/40Mhz disabled as well.
Aggie88
Feb 12, 2025Apprentice
I'm running on 7.2.6.21_5.0.20. I understand about having things in the basement but that is how I had my old RBR50 system configured and I just stayed the same.
- FURRYe38Feb 12, 2025Guru - Experienced User
Ya, keep v.21 loaded. What I have loaded. You'll be good there.
If disabling 20/40Mhz works then keep it disabled. Just won't effect 5ghz is all.
