DaveEdmonds
Jun 17, 2022Guide
All Amazon products will now not connect to Orbi RBR850
So about a week ago one of my Amazon Echo Studios reported it was not connected to the internet. This was after working fine for over two years. Attempting to reconnect to the SSID on the Orbi networ...
N3tworkDud3
Jun 18, 2022Apprentice
I've got the same firmware on my 850 series. Have one satellite. Have a few Amazon devices that connect fine. Possible Amazon did something on their end if only their products are having issues. Could be an issue with your account at Amazon too.
Didn't see where you state resetting the router and satellite(s) to factory settings and re-configuring. If you haven't tried that, might want to. It can clear up bizarre behaviors.
One thing you can try just to check the state of things with your devices is set one up to use your cell phone as a hot spot. If it connects, it may not have an issue.
Good luck!
