DaveEdmonds
Jun 17, 2022Guide
All Amazon products will now not connect to Orbi RBR850
So about a week ago one of my Amazon Echo Studios reported it was not connected to the internet. This was after working fine for over two years. Attempting to reconnect to the SSID on the Orbi networ...
DaveEdmonds
Jun 19, 2022Guide
I will try the threshold suggestion, I did earlier disable AX on 2.4 and no change but I haven't tried the CTS/RTS setting yet. Thank you for the suggestions.
N3tworkDud3
Jun 23, 2022Apprentice
Wasn't thinking about this earlier, but one set of my Amazon Echo 3rd party products required my SSID to be broadcast, not hidden - which I prefer. If you "hide" your SSID, maybe try broadcasting to see if that helps?
- DaveEdmondsJun 25, 2022Guide
Without me doing any other troubleshooting past what I did earlier, the two Amazon pieces of junk are now connecting to the Orbi network. I have no clue why they all of a sudden went back to working other than it must have been an Amazon related issue. Thanks to all that had useful suggestions.
- FURRYe38Jun 25, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
