stu3886
Oct 11, 2021Apprentice
Alternatives to orbi?? (considering replacing already)
Currently have RBK853 (router and 2 satellites) failing woefully with all these horrible firmware updates and unfortunately I just don't have the time to be a member of the Netgear Beta testing t...
Oct 18, 2021Guru - Experienced User
Ok. I'd say something on the modem is not blocking addresses correctly. Something the ISP should have a look into. Would be kind of concerning if the modem isn't blocking any addresses...
stu3886
Oct 18, 2021Apprentice
Hopefully will be getting an ONT with fttp next week, so may need to just wait till then and hopefully just use the orbi as a router plugged straight into the ONT.
in the meantime I'll speak to sky and find out why the firewall isn't doing its job properly.
could it be that the lastest firmware is already downloaded and stored on the orbi and that is why its saying its still available to upgrade?
