astainback
Jan 25, 2021Apprentice
AX4200 Router and Satellite - Wifi Devices lose connection for short periods of time
AX4200 Router and Satellite - Wifi Devices lose connection for short periods of time Firmware : 3.2.16.22_1.4.9 I got this recently. So far, the performance is great. My Nighthawk kept los...
astainback
Thanks Furry.
I am going to call support today and let them take a swing at it.
astainback
Called support.
They walked me through manually updating firmware. Went from 3.2.16 (see first post for rest of version number) to 3.2.17.12_1.4.14. The router did not see this automatically for some reason.
I just pushed the satellite firmware update as well, so I guess we will see now what happens.
- Mikey94025Jan 25, 2021Hero
astainback wrote:Called support.
I just pushed the satellite firmware update as well, so I guess we will see now what happens.If you still have issues with the latest firmware, do try changing this one earlier recommendation. I find it works well to improve wireless compatibility with older devices:
- Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings.
- astainbackJan 25, 2021Apprentice
I am trying to learn more about this :
Armor, Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings. Save settings and reboot the router and satellite(s).
I disabled Armor a while back.
I have googled and read up on the coexistence and CTS. Not sure about preamble stuff yet. Does this make the connections better? - FURRYe38Jan 25, 2021Guru - Experienced User
Let us know how it goes. Also try the suggested CTS change.
I just pushed the satellite firmware update as well, so I guess we will see now what happens.- astainbackJan 25, 2021Apprentice
Thanks Furry. I will.
I did change CTS to 2347.
I also cranked it back up to 100% signal.
Sounds good.
