astainback
Jan 25, 2021Apprentice
AX4200 Router and Satellite - Wifi Devices lose connection for short periods of time
AX4200 Router and Satellite - Wifi Devices lose connection for short periods of time Firmware : 3.2.16.22_1.4.9 I got this recently. So far, the performance is great. My Nighthawk kept los...
Jan 29, 2021Guru - Experienced User
NO, just on the RBR.
Under Advanced Tab/Advanced Settings/Wireless Settings
astainback
Jan 29, 2021Apprentice
I guess I assumed that was for the router and the satellite. So you are saying this is just for the router? If so, I am definately going to cut it down... I just didn't want to shorten the throw of 5 Ghz from the satellite.
- FURRYe38Jan 29, 2021Guru - Experienced User
Just the RBR.
- astainbackJan 30, 2021ApprenticeUpdate on my daughter's tablet.
She is having a hard time.
The connection keeps dying.
My wife and I are not having the issue.
She is as far away from the satellite as she can be.
When she brings me the tablet, she connects 5ghz.
When she goes back to her room... Her weak signal dies and it shows an authentication error.
It will connect 2.4, but I think it is fighting.
I turned the satellite to face it towards her room.
I am not sure if that thing is directional it not.
Tommorow, I am going to place it in the center of this floor. - FURRYe38Jan 30, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Any Wifi Neighbors near by? If so, how many?One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
