Captainmichael7
Nov 20, 2021Aspirant
Ax6000 download speeds max at 94 mbps via ethernet and wifi
I am only receiving 94 mbps via wifi and ethernet on all devices.. new orbi rbk 853 setup.. I have changed multiple settings and I have now downgraded firmware.. I am stuck at 90 mbps... If I connect ...
- Nov 20, 2021Yes, that is correct.. still only shows 100 mbps
Nov 20, 2021Guru - Experienced User
Has a full power OFF of the ISP modem and RBR for 1 minute or more then back ON been performed?
Do you have your prior router on hand by chance? If so, you don't have to connect the old router to the modem, just power ON the old router and connect the WAN port of the RBR to the LAN port of the older router. Check the connection status again on the RBR. If it doesnt' change to 1000Mpbs, I presume the RBR is faulty and needs replaced.
Captainmichael7
Yes a full reset has been done.
What I tried before this response was connecting modem ethernet to wan port of nighthawk router and then connecting ethernet from lan port of older nighthawk to wan port of rbr and switching to AP mode... it is showing 1000 mbps on the wan in the status screen
I was on the phone with netgear earlier before I switched the setup and they looked at the stats screen and didnt even acknowledge that wan was only reading 100 mb
I am lost at what is going on
- Captainmichael7Nov 20, 2021AspirantSorry.. I meant that the old nighthawk router is showing 1000 mbs in the wan status screen however the rbr is only showing 100 mbs
- FURRYe38Nov 20, 2021Guru - Experienced User
So with the RBR connected to the LAN port of the old router, the RBRs status page reports 100Mpbs?
- Captainmichael7Nov 20, 2021AspirantYes, that is correct.. still only shows 100 mbps
