UrbanL
Apr 04, 2020Guide
Bad connection to Orbi RBS850 satellite
Hello I bought an Orbit RBK853 (with RBR850 and RBS850) before Christmas 2019. I'm about to throw the device out and buy another product, because I have several problems so far and still no solution...
- Apr 16, 2020
Any older CAT5 cabling, I would upgrade for sure. CAT6 is mimimum now days.
Glad the system is working now. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Apr 05, 2020Guru - Experienced User
It maybe possible that this model has a built in router and wifi already...if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try setting manual channel to 1, 6, 11 or 13. Use a web browser to log into the RBRs web page to change channels, you can't change channels using the Orbi app.
UrbanL
Apr 16, 2020Guide
thank you for the answer. I have now had the time to reinstall everything again. So far it looks like I have no more connection problems. But every now and then the network is still very weak 3Mbps instead of 500Mbps. I will now renew all my old Ethernt cables to Kat7 and hope to have a really good network :-) Thanks again!
- FURRYe38Apr 16, 2020Guru - Experienced User
Enjoy. :smileywink:
