JJNorcal
Mar 12, 2020Tutor
Can't acess Orbi RBK852 when configured as an AP
I'm trying to replace an R7000, which works fine in AP mode behind an erlite router which is in turn behind a Netgear CM1150v Comcast modem. The R7000 still works OK, but I have to reboot it a coupl...
Mar 12, 2020Guru - Experienced User
This should have worked. Or 192.168.2.85
JJNorcal
Mar 13, 2020Tutor
Thanks FURRYe38, I appreciate your advice. I have decided to take Netgear up on their offer to try another unit, and then escalate to engineering if/when needed.
I almost went down the path of letting RBR be the main router, but then I would have to reconfigure my network, set up new DHCP reservations, and set up port forwarding rules for my NAS. I really prefer separating router and AP functions.
Anyway, thanks again!
- FURRYe38Mar 13, 2020Guru - Experienced User
Ok sounds like you just had a bad unit then. You'll be able to get into the RBRs web page in AP mode. It does work. Let us know how the new replacement works for you.
