Hondamaker
Mar 17, 2021Aspirant
Can't get more than 22Mbps anymore
I ususally get 100 or so Mbps download but recently I've only been getting 20 or so. Nothing has changed here AFAIK. I've rebooted both the modem and the Orbi several times, I've moved the Orbi out i...
Mar 18, 2021Guru - Experienced User
What devices are you using to test speed with?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Has a factory reset and setup from scratch been performed since last update?
Hondamaker
Mar 27, 2021Aspirant
And no, I haven't done a factory reset after last update. If all else fails I may try that if you think it might help.
