Hondamaker
Mar 17, 2021Aspirant
Can't get more than 22Mbps anymore
I ususally get 100 or so Mbps download but recently I've only been getting 20 or so. Nothing has changed here AFAIK. I've rebooted both the modem and the Orbi several times, I've moved the Orbi out i...
Mar 28, 2021Guru - Experienced User
Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Be sure to mark your thread as solved so others will know.
Enjoy. :smileywink:
Hondamaker
Mar 28, 2021Aspirant
How do I make a back up of my configuration?
- FURRYe38Mar 28, 2021Guru - Experienced User
Log into the RBRs web page and under Advaced Tab/Advanced Tab/Administrattion/Backup
