atejwani
Aug 20, 2021Apprentice
CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7) dropped downloads speed!!!
Prior to CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7), I was consistently getting 1.2gb - 1.4gb download speeds. Now it is below 650mb. Nothing else, besides the firmware updates, ha...
Oct 05, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX With Cable Modem products. Most of the people who watch that forum are more likely to have experience with Orbi with cable modem and know how to work it better than those of us who follow this forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
atejwani
Oct 05, 2021Apprentice
I have FURRYe38 in the Orbi with Built-in Cable Modem section of Netgear Community:
There seem to be bits and pieces in various sections and posts cross-referencing each other. If the only solution today is "hacking" it, and it seems that these might be some of the steps:
1) In browser console, changing HTML/CSS code (to have "Yes" button show up) to roll-back from older version
2) Using Debug site to enable Telnet and then
3) Telnet to disable auto-update
A "FAQ", be it an interim fix, till the the firmware upgrades are provided, would at least get us past this issue.
Thanks,
Al
- FURRYe38Oct 05, 2021Guru - Experienced User
Will respond there.
Thank you.
