Freemaak
Aug 21, 2021Guide
CBR750 Fails after firmware update
I recently updared the firmware on my Orbi CBR750 to the latest v4.6.3.6_2.0.48 update. I can no longer establish internet connectivity. Prior to updating my connection was fine with no issues. My ISP...
Aug 21, 2021Guru - Experienced User
Freemaak wrote:
I recently updared the firmware on my Orbi CBR750 to the latest v4.6.3.6_2.0.48 update. I can no longer establish internet connectivity. Prior to updating my connection was fine with no issues. My ISP says nothing is wrong and the Netgear tech support is no help considering I'm outside my 90 day purchase window.
The cable connection error is with the cable connection continuously failing to connect. I've used new cables and moved it to other cable ports in the house known to work in the past.
Please help.
Freemaak
Aug 21, 2021Guide
Yes. I've done a cache clearing reset...removing the coax cable, holding the reset for 30sec, and power cycling 3 times in a row. Same error.
- FURRYe38Aug 21, 2021Guru - Experienced User
Has a power OFF for 1 minute then back ON with the Orbi system been performed since last update?
You only need to press the reset button for 15 seconds then release...
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.- FreemaakAug 22, 2021Guide
- Yes
- I did a "shock" reset w/ a netgear tech which was the 30-30-30 reset according to the case number.
- Connection Error (Check RF connection)
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.- ISP on-site technician performed all these actions, and nothing is wrong on their end.
I've been in contact with NETGEAR and they're going to send a replacement device. My ISP installed a temp router so I won't be troubleshooting further. I still believe the firmware was the root cause, but I can't say why/how a firmware update would break the modem.
- FURRYe38Aug 22, 2021Guru - Experienced User
Ok, let us know how the RMA goes...
Avoid doing the 30-30-30 reset. Its not needed. Only a 15second press will do.
