Freemaak
Aug 21, 2021Guide
CBR750 Fails after firmware update
I recently updared the firmware on my Orbi CBR750 to the latest v4.6.3.6_2.0.48 update. I can no longer establish internet connectivity. Prior to updating my connection was fine with no issues. My ISP...
Bobkc
Aug 26, 2021Star
I first reported this problem in that after the firmware update, upload speed did not change and download went from 900 to 600. The proposed fix did not work with me as the status remains unchanged. If you would like additional information, please IM me and I will provide. Not sure if this is the same issue that was part of this string of communications as our provider is Xfinity not Cox. Is there a fix coming tomorrow as I read in one note???
vkdelta
Aug 26, 2021NETGEAR Employee Retired
this issue has nothing to do with Xfinity as this was specific to Cox network changes.
Please create separate topic to avoid mixing of multiple issues.
- BobkcAug 26, 2021Star
Thanks Vkdelta and when the email came through reporting an update, it had a similar subject to an issue that I reported 8 days ago. Was hoping the issue was resolved. New to the community and still learning protocol.
