Jun 12, 2022Guru - Experienced User
Enable Email Logging and Router Reboots
NOTICE:
For ANY users seeing mysterious reboots of there 7 or 8 series RBR routers rebooting at random or at specific time frames, we'd like to ask you to enable Email Logging of the RBR and config...
- Jun 21, 2022
Ok, enabling email logs seems to help stop the RBR mysterious rebooting. Mines been online for 4+ days:
Uptime would have been more however we had a brown out last Wednesday.
00_Jenn
Jun 13, 2022Star
Got 2FA set up but can’t find that. Just 8 digit backup codes or option to use authenticator app that scans a QR code.
Timothy88
Jun 15, 2022Luminary
In the line under 2FA you should see 'App Passwords' If you click the > it should ask you to enter your google password. Once you are in there choose 'select app' and you can create a custom name like OrbiMail for example and it should generate the 16 character passcode.
