bmwr75
Dec 15, 2021Star
Fiber Modem and Orbi connectivity problem
Recently purchased the Netgear Orbi RBK753S High-Performance Whole Home Mesh WiFi System from Amazon. Cannot get it to work when connected directly via ethernet cable to my Adtran SDX 621 fiber mode...
- Dec 17, 2021
My ISP did an update on their fiber modem ONT and the Netgear Orbi started working as it should after a restart.
Dec 17, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
