AwesomeQA
Aug 17, 2020Apprentice
Firmware 3.2.16.6 Web GUI bug
I have updated RBR850 to Firmware 3.2.16.6. Once you change any device name in the attacjed device list, all devices will disappear from the attaced devices. I did hard reset the Router, and chang...
AwesomeQA
Jan 27, 2021Apprentice
The issue is still with the latest firmware verion, I did hard reset and soft reset.
This issue only happens when I connect group of RBS5 Sats to RBR850
AwesomeQA
Jan 29, 2021Apprentice
I found the problem.
Once I unplugged RBS50 sat the admin web will show the attached devices.
So Netgear should test it and fix it.
