Halvorho
Mar 27, 2025Aspirant
Re: Firmware 7.2.6.31 Issues – Connection Drops & Speed Problems
I have the same issues all of a sudden on my 960 series Mesh setup that has been working great for 3 years. This network is way to expensive to have flaws like this. Apparantly as mentioned above t...
Mar 27, 2025Guru - Experienced User
Maybe you should do more searching and check to see if NG has done something to help you with your issue:
This is newest FW that just came out about a month ago.
