droog
Feb 04, 2021Star
Frequent internet disconnects
RBR 850 internet disconnected Hi, I'm seeing frequent (at least 1x or 2x daily) internet outages these days. The log in the admin section of the router says "Internet disconnected". ...
Feb 04, 2021Guru - Experienced User
You might try it. I'm in the USA region.
I'm using defualt NG NTP and have never see this issue:
Firmware Version: V3.2.17.12_1.4.14
CPU Load: 12.12%
Memory Usage(Used/Total): 491 MB/867 MB
System Uptime: 8 days 20:06:57
eightninenine wrote:
I have been using time.google.com for NTP for a long time, and my issues have only started occurring with greater frequency. When I get time later I will do a full reset. However, this doesn’t feel like a great solution, more like Netgear is grasping at straws. I am hoping that I can backup my settings and restore, otherwise this is a horrible task.
eightninenine
Feb 04, 2021Aspirant
Hi FURRYe38,
Thanks in advance, I have read these forums before and you are a great help to many people it seems.
I have loaded what I believe is the latest firmware: V3.2.17.12_1.4.14 (quite the identification!).
I use a DrayTek Vigor 130 as the modem. I even bought this specifically as I read it was highly stable and reliable.
I have used many of the wireless settings recommended by you in a number of posts, and other than that I use Google’s DNS servers and Google’s NTP server.
