detroitsandman
Oct 16, 2023Guide
HELP!!! Orbi 960 Series AXE11000 | Hardwire speeds of router and satelite fine, wifi drops randomly
Hello, I have a NETGEAR - Orbi 960 Series AXE11000 Quad-Band Mesh Wi-Fi 6E System (3-pack) - White and have had it for about 11 months with an extra satelite. (In a 2500 sq foot home). It w...
detroitsandman
Oct 18, 2023Guide
So at some point last night, I got some speed back. About 100-140MBPs wireless (depending where I am) and the hardwire speeds are consistent around 1GBPs off the router, and 700MBPs off the satellite. As far as I can tell all of my devices are online, but the webpage only shows 30 (of about 60 normally)
The web page is still showing no satellites, but they are working as I can hardwire off them and get pretty good speeds (700MBPS). They will not sync at all.
I am also confused why speeds comes back at times and goes away with no rhyme or reason.
Is a factory reset the only option at this point? (I cant change the 5ghz channel either)...
SLK-Purdue
Oct 18, 2023Luminary
I have experience this problem with 850 hardware and send extensive test results to Netgear. My belief (without explicit evidence) is that the power-on "reset" on the satellite is incomplete and does not reset "factory" or "out-of-box" conditions. The satellite retains information which is causing issues during pairing and syncing. I don't have a good solution for this other than to suggest you reset and pair satellites wirelessly and one at a time with only that satellite powered on. After wireless pairing and sync, wired will usually work. Good luck and I hope Netgear can isolate and correct this soon.
Scott
ps. I have never seen the satellite with a solid white as described in the pairing instruction in the WebUI for anything other than a first-time out-of-box device. I believe that is also a clue.
- FURRYe38Oct 18, 2023Guru - Experienced User
SLK-Purdue Do you think a 30-30-30 reset would help at all?
Scott
- SLK-PurdueOct 18, 2023Luminary
I don't believe 30-30-30 is relevant for newer hardware. The purpose of this procedure was to bleed off any charge held by the capacitors that were using to keep data in "non-volatile ram". With the coming of flash ram, there was no longer any relationship between data retention and remaining charge on the board. Orbi 960 series keep "NVRAM" parameters in flash.
Scott
K. Was wondering. I only had one event not similar to this thread, just where I got a FW from another and it was loaded well on his unit but mine didn't seem to like it and could not normally FR the RBR. I had to do a 30-30-30 reset and got the RBR working normally again. Was only one experience like this. Was on my 960 series. I can't attest to weather the process did anything or did, just know that it corrected what ever was in a bad state.
I would agree though, I've always had some level of doubt on the actual FR process and what it does and doesn't do beside just wiping out user configurations and settings. I would like to see a more complete FR process on all units. Button or Web UI ERASE. Seems to be needed.
- detroitsandmanOct 18, 2023Guide
What is a 30-30-30 reset?
I spent 3 hours on phone with L2 support, did factory resets on everything. Worked for maybe 6 hours and it is doing it again...
To escalate to L3 support they need more information, and said it could take weeks or months....
Any other ideas here? I am about to buy a Linksys and be done with it...
Could it be one wifi item interfering with everything? I haven't added anything I can think of.
- detroitsandmanOct 20, 2023Guide
Thank you for your responses thus far, I appreciate it very much.
I have a couple other questions if you happen to have some knowledge around them:
- Could a device or group of devices cause this?
- I ended up setting un an entire new network with a new name and have about half my devices connected. (20-30) I ran 60+ for 11 months with no issues prior to this, so I am slowly adding things back to see if that could be the cause. The main items I have offline are my 10 Nest Cameras (As they were always the first to drop offline). As they are a few years old, could that be the cause? Should I isolate them to the IOT 2.4ghz network?
- I have one satellite that intermittently shows a poor backhaul status. Could that be a factor?
- I am going to hardwire the backhaul, but wanted to pose the question
- Any other things I can look at to try and determine what was/is the cause? The logs don't tell me much, but I am not very savvy in that respect. (I was basically looking for errors or some differences in what was captured, which I could not).
- Any other thoughts or advice are appreciated.
- SLK-PurdueOct 20, 2023Luminary
I have seen no evidence that other devices contribute to this issue.
I would try to sync wirelessly first and then revert to wired. I have had better luck with wireless sync.
Scott
Any ideas what it could be?
I hooked up a Linksys Velop system with two satellites and was getting the same thing happening. Made me think its either devices or interference from somewhere I can't detect.
Also the new network name has made it stable for a bit, do you think there could have been some legacy cache or something in the old one perhaps?
Sorry. No clues.
Scott
- detroitsandmanOct 23, 2023Guide
Update:
New network is still stable, Ive added a device or two a day with no issues so far.
Has anyone else ever had anything like this? Could it have been some legacy cache or something like that causing some sort of intermittent interference?
I can't come up with anything else, and NetGear support hasn't been helpful either.
Open to any opinions, ideas, or otherwise. Thank you
- AnalogKOct 23, 2023Aspirant
I spent the day troubleshooting what sounds like your issue. I have a 960 router with 5 satellites on a wired backhaul. My hardwired devices get 1.7Gbps. 6 Ghz at 900Mbps. 5Ghz at 450Mbps. 5Ghz dropped to 15-50Mbps.
I performed 3 factor resets, tried AP and Router mode, and tested with and without satellites. I thought I found the issue with Apple's Limit IP Address Tracking, but this only impacts connections to the satellites, not the RBRE.
I just changed the password on my 6E connection and the issue stopped. I'm waiting for another occurance and a callback from Netgear.
- detroitsandmanOct 24, 2023Guide
Good luck on the call from Netgear, they almost never call back. (In my experience, I always have to call back in and explain it to the next person). I got to L2 support, and to go to L3 apparently takes weeks to months...
Your password change might work. I setup a new network name and have been slowly adding me devices back on and its been stable a few days now. Given they even sent me a new router, I'm not sure what else it could be. (Unless as noted a few replies up, the factory resets really don't clear out the satellites).
Please do reply if you come up with anything or get any information from Netgear, this has been driving me nuts for weeks now.
- detroitsandmanOct 26, 2023Guide
So I got the issue again yesterday and this morning, but it only lasted a brief amount of time, was not as slowed down as before, and I ultimately did not do anything to restore it.
I want to think its interference from a neighbor, but I was running inssider (https://www.metageek.com/downloads/inssider-win/) and I wasn't seeing any interference or signal loss.
Leaves me rather clueless, but figured I would share nonetheless.
- detroitsandmanOct 27, 2023Guide
Next Update :
So all my satellites went offline yesterday and my speeds tanked. Only two came back on with the other saying disconnected. Speeds came back in the morning without me doing anything, and looking at the interference tool, I don't see anything. (All my signals / channels look green).
The disconnected satellite would boot up to the blue light every time, even after I removed it and factory reset it 3 times!!!! If I hardwire to it, it still puts out good speed (800MBPs), but the app nor the Orbi login recognize it. I have no idea how its still working?
I don't know what to do if I can't factory reset it. Is the only way to factory reset the entire system? I'd rather not do that again as each time it seems to take longer and longer to setup.
- FURRYe38Oct 27, 2023Guru - Experienced User
A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.Press the back reset button for 15 seconds then release on the RBS first then RBR or kick of the RBR reset using the ERASE button on it's web page.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System - detroitsandmanOct 27, 2023Guide
So I do have to factory reset the router again? I was trying to avoid it as everything is actually working great right now, but that rogue satellite doesn't seem to be recognized anywhere.
Do you think if I factory reset the satellite again and let it sit with no power for awhile that could clear it?
(Sidenote: Waiting on a call from Netgear as I sent them debug logs and some other information for L3 to look at)
Yes try a reset on the RBS.
The best advise we can give people is to start a new config, power on one RBS and wait for some SOLID light or most often blue or magenta. And then add the RBS WIRELESSLY via the WebUI. Power off the RBS. Then rinse and repeat with any additional RBS(s). Pair RBS one at a time even if you have more than one. For ethernet connected RBS, after things come up wirelessly, you can move to wired backhaul but don't start with wired backhaul for those RBS that are ethernet connected. Wirelessly connect and sync RBS first before ethernet connecting RBS.
- AnalogKOct 27, 2023AspirantI picked up a couple of WAX630e APs to rule out LAN or interference. They have been running just over 24 hours. I'm getting between 800-900Mbps.
FURRYe38 so just reset the satellite again or the router also?
Try a RBS on the RBS. Press reset button for 15 seconds then release. White for the front LED to blink white or pulsate WHITE for about 3 minutes. Then use the RBRs web page Add Satellite to add the RBS. I'd do this with the RBS near or in same room as the RBR.
- AnalogKNov 15, 2023AspirantI replaced my 960s with WAX630Es. I can replicate slow connectivity by setting the transmit power to maximum and placing APs too close to each other. Setting transmit to 50% resolves the problem.
- detroitsandmanNov 15, 2023Guide
Is that something you can adjust on the 960?
I agree once I get either a refund or a replacement from NetGear, I'm likely to explore other options after this experience.
- FURRYe38Nov 15, 2023Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
Did you try this already?
- detroitsandmanNov 16, 2023Guide
Yeah I am pretty sure that was one of the many steps I took with Pro Support.
They did just send me a beta firmware update to try, but I'm waiting to hear what the root cause was and how they fixed it before I waste any more time, effort, and energy on it. (Not to mention stress)
I'll share the root cause and whatever they send me with this thread as well.
- FURRYe38Nov 16, 2023Guru - Experienced User
So you bought a new same model system and that doesn't reproduce the problem right on current release FW?
