premier87
Mar 03, 2022Aspirant
Intermittent connectivity in a business setting
I recently purchase the RBK753S Router/2 satellite system from costco, for my wifes Therapy practice. There are 8 offices/therapists, and two of them upstairs are experiencing slow connectivity and o...
Mar 03, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
If the building has "thick" stone walls this will be a factor in why the remote RBS in the other building is having problems. The signal has to go thru two "thick" stone walls and the signal is being degraded severly.
I recommend if you can, a CAT6 or CAT6A lan cable installation between the RBR and remote RBS building would solve this issue.
premier87
Firmware is v4.6.5.14
I'm not sure of the ONT model, its in a basement room that I don't have access to. The distance between the router and satellite 1 is about 35 ft. Distance between router and satellite 2 upstairs is about 50 ft. Distance between sat 1 & 2 is about 20 ft. The part that makes me think its not the stone wall thats causing the issue is the therapists in the offices in the lower level on the other side of that stone wall that are connecting to sat 1 are not having any issues.
- premier87Mar 03, 2022Aspirant
and no we don't have coax in the building, at least not to the locations we'd need it. I'd need to explore whether or not itd be possible to get cat6 from the router to sat 1, sat 2 would be impossible as the landlord would not allow us to run it on the exterior.
- FURRYe38Mar 03, 2022Guru - Experienced User
You can load this up and see if it helps:
Load up the RBS first then RBR lastly. I recommend that you take a laptop with the RBS FW file on it and wire connect the laptop to this one RBS via ethernet in back to update it as sending from the RBR side may cause problems if this one RBS isn't getting good signal.
