msinex
Jul 27, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
Mar 10, 2021Guru - Experienced User
One can certainaly try the downgrade and the telnet modification that was mentioned.
DNS_PROBE_FAIL
Mar 10, 2021Luminary
Running an internet connected router with old firmware is exposing yourself to security risks and as soon as you upgrade firmware back to a new version, it undoes that fix so you’d get the DNS errors again.
- Retired_MemberMar 10, 2021
This is not correct, I still have my telnet enabled and running the fix I mentioned earlier.
I dont know when they removed the possibilty to enable telnet, but for sure know that they dont clear the telnetd_enable from nvram on update
Output from cli today:
root@RBR850:/# version
Release version : Orbi 11AX Router RBR850
U12H404T00/V3.2.17.12/1.4.14
Time : Dec 28 2020 22:06:59
CFE version : V1.0.12
root@RBR850:/# nvram show |grep telnet
telnetd_enable=1
root@RBR850:/#
- TyneBridgesMar 10, 2021Tutor
Me too! My modem is only a few days old and I regularly see DNS errors. I've logged a support ticket and hope that anyone else with the problem will too, so that Netgear see that they have to fix their firmware.
- DNS_PROBE_FAILMar 10, 2021Luminary
Retired_Member Hopefully telnet is not accessible externally, it's an insecure protocol and not advisable to keep enabled long term in any network environment.
I thought you said telnet was disabled upon firmware upgrade, but I guess you said the DNS settings changes were reset, not telnet enable.
I did send a link to your post and findings to NG support, hopefully they read it in between their nap times and whatever else they do. Thank you
- FURRYe38Mar 10, 2021Guru - Experienced User
I would presume that you updated your system over the top of what you had and have not done a factory reset since. I tried this after v12 was applied to mine however mine was reset. I could not enable telnet on v12 using the enabler from a command line.
Retired_Member wrote:This is not correct, I still have my telnet enabled and running the fix I mentioned earlier.
telnetd_enable=1
root@RBR850:/#
Telnet is old, outdated and easy to sniff tool for sure, so I am in the process of getting dropbear (ssh) up and running.
Besides utelnetd which is the one running on orbi has the switch "-i br-lan" for binding to the lan-interface only, and internally I like to think I have control :)
That is correct I have done the firmware updates without doing the factory-reset, that would explain the different behavor.
FURRYe38 wrote:I would presume that you updated your system over the top of what you had and have not done a factory reset since. I tried this after v12 was applied to mine however mine was reset. I could not enable telnet on v12 using the enabler from a command line.
telnetd_enable=1
root@RBR850:/#
- energieMar 10, 2021Luminary
I tried reaching out to Netgear to make them aware of this issue, however because the 90 day support window expired I am unable to do so.
I don't want or need phone/chat/mail support to ask questions on how to setup my router or how to turn on/off the router. I want to make Netgear aware there is a serious fault with their product that affects all customers. However with their 90 day policy in place Netgear effectivily blocks any communication. Again this shows that Netgear support is basically a department that has been set-up to monetize basic help questions and not to provide actual product support when it comes to solving bugs.
Netgear needs to fix the DNS server / firmware.
It also affects other product lines:
This forum is scattered with it. Also FURRYe38, it would be great if you would stop telling people to use workarounds without telling that there is an actual issue with the DNS server / firmware that only Netgear can fix. As you are doing in the thread I linked.
Fun fact, for the Orbi Pro they fixed this problem on 2020-09-08 with V2.5.3.110:
As it reads: Fixes a DNS problem that intermittently causes loss of connectivity. This could make you wonder that Netgear simply deemed the Orbi product line to be finished and no active firmware support is given and they moved on to other product lines. Considering no response up until this date has been given.
Users can reach out to forum moderators as well if they feel to let them know there concerns.
Again. this issue is being reviewed with NG at this time. Not information on feedback or when any fixes will be forth coming as NG will NOT devuldge this information.
Forum a forum perspective, this is beating a dead horse. Users will need to contact NG support about this and wait for the fix to appear.
I post how I see fit. Thank you.
Good Luck.
I get the dilemma. Basically the Orbi would be a nice wifi system if the DNS server / firmware is working correctly. However in the current state it isn't. DNS handeling is basic functionality and the Orbi is failing at it. Causing DNS errors / timeouts, which in turn causes all sorts of end-user problems: websites not loading, streams stopping/not loading, mobile applications not loading correctly etc.
I am actually looking in to switching the Orbi for the Asus XT8, as I am doubting whether or not Netgear will actually fix the issue. The reports on connectivity issues with the XT8 are not much, as far as I can tell. However the only downside is that the 2,4 Ghz channel is limited to 2x2. Which is a small step backwards as I think the Orbi has 3x3. This is only a downside though if you have 3x3 wifi-5 clients.
- arlomikeMar 10, 2021Apprentice
As a short term workaround, have you guys tried overriding the DNS server on your computers and just point to an open DNS server? In my case, I spun up a piehole server and and repointed my computers to piehole. Other IOT devices are SOL tho but users don't interface w/ those anyways.
Also, I find it stupid that Netgear doesn't allow you to set the DNS server it hands out in the DHCP settings. I guess their protecting their paid security service but don't see why they can't allow that for it.
- energieMar 10, 2021LuminaryStrange, I can imagine the engineering team not being aware if the support desk is blocking any escalation. If thats the case it really shows how bad the Netgear support department actually is.
However, the engineering team has fixed the same problem for the Orbi Pro, so in some way or form they have been made aware. See my earlier reply w/ link. The main difference I guess is that the Orbi Pro is aimed at business users for which they offer a different level of support.
I also don't understand the need for screenshots, since you explained it to the previous tech agent. The problem is pretty straightforward: The DNS server is not working properly. Which causes DNS errors and websites, streaming services, apps etc to fail.
Netgear needs to fix the issue with the DNS server / firmware. - DNS_PROBE_FAILMar 11, 2021Luminary
Once the steam escaped my ears and I calmed down I decided to at least try to help everyone out, even if I return the system.
- I disabled IPv6, switched to IPv4 and recreated the error going to a known-good website. Error on NewEdge browser is: ERR_NAME_NOT_RESOLVED
- Took screenshot of the DNS error in browser and uploaded it to support
- Pasted all logged events from Administration, Logs into support
- Backed up my router config, zipped and uploaded to support
So they have literally everything they have ever asked for from me, some things they've receved multiple times.
- Ace321Mar 11, 2021Apprentice
Unfortunately I have no hope that this issue will be fixed any time soon. I have provided all the information requested many weeks ago (logs, screen shots etc). Still no resolution. In my opinion, only solution is to set static DNS at each device level. If that solution is not acceptable to you, return/sell your device and move to other device.
- Mikey94025Mar 11, 2021Hero
DNS_PROBE_FAIL wrote:Once the steam escaped my ears and I calmed down I decided to at least try to help everyone out, even if I return the system.
Curious - The DNS failure is intermittent so difficult to reproduce on demand. Did you set something up to repeatedly visit a website in a browser until it fails or something like that? It could be a useful testing tool for Orbi owners who believe they are unaffected.
- energieMar 11, 2021LuminaryI'm sure it affects the entire Orbi AX product line that use the same firmware. Other product lines like the Orbi AC or Orbi Pro use a different firmware. Which you can recognize by the firmware name/version.
The negative point in all of this is that a lot users are unable to identify the actual problem, which is understable as the users are consumers using consumer grade hardware, and Netgear support has been unable to acknowledge or identify this as an actual DNS server / firmware issue based on incoming reports.
Meanwhile this issue has been resolved last summer for Orbi Pro.
Netgear needs to fix the DNS server / firmware. - DNS_PROBE_FAILMar 11, 2021Luminary
No, I didn't set something up to repeatedly visit a website or list of sites, I just manually typed in one website after another - trying to use sites that I haven't been to recently so it's doing an actual DNS lookup and not using cache. (Browsers can cache DNS lookups, chrome does this) Within about 10 sites or so I'll get the error every time.
To capture it for support, I just hit the print screen button on my keyboard then pasted into pain and saved to upload. You have to act fast to get the screenshot this way because the browser will retry on DNS failures and usually resolves the second time.
Netgear needs to fix their firmware.
- JBlank912Mar 16, 2021Tutor
I was running almost flawlessly for 2 years, last week the DNS problem started. IPhone and Android phones started loosing connections. Reboot router fixed it for a while and back within a day or less. Seems to be getting worse each day. Latest Firmware update I think was a few weeks ago. I have 2 Satelites with the system. One of the strangest parts is we have 1 system hardwired to a Satelite and that would hold connection fine while the cell phones or tablets loose connection. LAst night nothing would connect except TV's could stream Netflix and You Tube. Makes no sense.
- DNS_PROBE_FAILMar 16, 2021Luminary
It sounds like your system had older, working firmware and wasn't updating firmware automatically, then for some reason it updated and the more recent firmware has the issue. Sometimes a reboot after power drop or something can initiate that. It's speculation but the fact that it was working and now isn't points to firmware update being a possible cause.
- FURRYe38Mar 16, 2021Guru - Experienced User
My system has been on v12 since 1-21-2021
and it was manually updated to v12 since v12 was not put on NGs update services by NG. It's only for manual download.
- tak1313Mar 16, 2021Luminary
I assume the AX line does NOT have IPv6 enabled by default, so you have enabled it? If so, it's a shot in the dark, but if you disable it, do the errors persist? PERHAPS these routers handle IPv6 poorly?
https://www.internetsociety.org/resources/deploy360/2014/dns-considerations-for-ipv6/
I might try that and see. Right now I'm checking a different line, to see if the problem re-appears. My Windows 10Pc got a new 2.5Gb LAN card installed. It was connected however I'm trying the old Intel 1Gb wired connection to see if I see anything first.
My ISP doesn't have native IPv6 so I use the 6to4 configuration. Here what I have been using for past few months with no DNS problems until today:
I just checked my NTP settings, I dould have sworn that I had DST enabled, however it was not. It's enabled now. I'm going back to my 2.5Gb LAN card connection and monitor again. The 1Gb LAN card has not seen anything thus far since I change a while ago.
FURRYe38 wrote:I just checked my NTP settings, I dould have sworn that I had DST enabled, however it was not. It's enabled now. I'm going back to my 2.5Gb LAN card connection and monitor again. The 1Gb LAN card has not seen anything thus far since I change a while ago.
I noticed a lot of Reddit users were posting DNS problems with older Orbis (RBR50, etc) with the switch to DST. I don't recall, but I believe at least a few that I read stated theirs were fixed by enabling DST; however, this problem appears to have been going on even when DST was not in effect, so it may be a cause for SOME people's problem at least.
Ya seems that some are having problems regardless of NTP or DST, espeically here.
I've since gone back to my 2.5Gb LAN card and have not notice anthing since this morning and re-enabled DST on mine. Will have to watch this over the next day or two and see how it goes. My Orbi 50 series hasn't seen this for me. Also using similar 6to4 DNS configurations.
Overall, I would recommend all users reach out to NG support and let them know about this for those who have not contacted support yet.
- msinexMar 17, 2021Apprentice
Just got this email from Netgear today asking me to join their "Netgear Champions" program to become "customer advocates" where I can earn points and giftcards for sharing my Orbi experience! Maybe we all need to join this program and see how many points we can get by sharing our actual Orbi experience....
- bullm00nMar 18, 2021Virtuoso
I just checked mine too - and DST was not enabled, but the time was shown correctly. I enabled DST and then the time was an hour ahead! So I disabled it again. Next I chanced the time to Central Time and the time was an hour behind Central Time. So I re-enabled DST and Central Time was correct. Then I put it back to Eastern Time and, with DST, that was now correct too! Something flakey is going on with NTP settings.
That said, I have not seen any DNS issues.
