msinex
Jul 27, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
vajim
Apr 12, 2021Master
Ace321 wrote:A new firmware just showed up 3.2.18.1 in my 750. Let me install and see if this issue is fixed.
wow...you're brave
DaytonaZ33
Apr 12, 2021Star
I solved my issues by buying two Eero Pro 6’s and setting them up in a wired backhaul configuration. Will not be buying Netgear again.
Good luck to the rest of you still on the Orbi AX.
- ed-winApr 13, 2021Guide
I solved my issues by buying three ASUS ZenWiFi AX (XT8). Work great and have a lot of configuration options I was missing in the Netgear Orbi. Will not be buying Netgear again.
