msinex
Jul 27, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
Jun 11, 2021Guru - Experienced User
If you have a 7 series, why don't you contact Christian_R and ask him for the beta?
SeaRefractor wrote:Wait 6 months to a full year, if it actually exists. How easy it is to claim access to a beta and then say the NDA prevents showing screenshot proof lest legal issues.
If it's true, now I'll be angry how long it takes to come to consumers. If it's false, thanks for kicking the hornets nest of customer dissatisfaction.
Ace321
Jun 11, 2021Apprentice
This Beta firmware is as good as official version. Zero issues.
- rgautierJun 13, 2021Apprentice
I have updated my router and two satellites to the beta firmware, v3.2.19.4. I reset the network connections and manually rebooted all three devices (router, satellite, satellite in that order). After releasing and renewing device IP settings on a device I knew had issues, I (so far) have not had issues with that device (after trying to get it to break for about 30 seconds, I could not).
I will keep the community updated, but I am hopeful.Thank you, @Christian_R for providing the beta firmware.
Rich G
P.S. The config of the dnsmasq run line does not appear to be changed, so I'm not sure what they changed:
dnsmasq -h -n -c 0 -N -i br* -r /tmp/dns/resolv.conf -u root
DNSBench shows better performance than outside router for DNS lookups except for 'cached' - I am assuming that dnsmasq is still providing no caching capability on the router. I've structured my layout to point the Orbi at the DMZ router DNS and utilize it for cached entries - at 7 ms delay, it's probably not going to be noticeable. We'll see when I boot up the games later today.
- stshJun 13, 2021StarIt did change. They did exactly what I was doing before. And it should work just fine.
They moved resolve.conf from /tmp to /tmp/dns
If this is how it runs in the new firmware that will solve all of the dns issues.
