Rogelio1
Jul 09, 2022Apprentice
iPhone 12 Pro loses WiFi connection with RBR850
I’ve had the exact same problem for the last 1.5 years and NOTHING has solved this. iPhone 12 Pro — I’ve done everything mentioned above — static IP address, factory reset Orbi, CTS changes, dropped ...
Aug 16, 2022Guru - Experienced User
Rogelio1
Aug 16, 2022Apprentice
Spoke too soon — just did it a minute ago
Dropped off Wi-Fi. Showed ip address of 169.254.152.15 and subnet mask of 255.255.0.0 for two minutes … then eventually latched back onto Wi-Fi auto dhcp (correct subnet / mask / router) — phone moved back and forth between router and sat1 and disconnected as usual once planted/sitting 15 feet from sat1 (50% power)
