guardtorah
Oct 01, 2020Follower
Is the CBK750 compatible with the AX6000 series (RBK853)
I don't see a cable modem built in for the AX6000 series (RBK853), so I am wondering if the CBK750 is compatible with the AX6000 series (RBK853) if I want to replace my cable modem but have the ultra...
- Oct 01, 2020
If you already have RBK853, dont buy CBK750. Just get a modem to put in front (such as CM2000).
Please make sure your ISP supports CM2000 before you purchase.
Oct 01, 2020Guru - Experienced User
RBK are router only "Kits". No built in modem. CBR or CBK's are Orbi systems with a built in modem.
I presume the RBS7 and 8 series from the RBK7 and 8 series kits maybe compatible with the CBR750 as this is a AX supporting system. Something to ask NG support about to get there official word on.
IF you already have a RBK8 series system, I would avoid getting the CBR750 and get a NG CM1000, 1100,1200 or CM2000. The CM2000 would be best was both the RBK8 and CM2000 support 2.5Gb connection rates on there WAN ports. Mine works great with the CM2000.
vkdelta
Oct 01, 2020NETGEAR Employee Retired
